1999 GS 300 Trottle Position Sensor
08-01-12, 07:40 PM
Just wanted to know if the throttle position sensor is easy enough to replace myself.
08-01-12, 08:10 PM
Yes it is
08-25-12, 08:41 PM
yes you can do it! Finally changed mine.
you'll need torque driver, philips screwdriver, multimeter and of course working TPS.
08-25-12, 08:51 PM
Im pretty sure its the same specs as well for the gs. If you dont have a multimeter a obd2 scanner works as well to get the tps in specs.
Jacob0015
07-15-13 09:17 AM
ynvme
10-20-07 08:11 AM
frotiss
Maintenance
08-07-07 05:11 PM
ted920
Performance
11-02-04 08:33 AM
1999 ,
300 ,
99 ,
cost ,
es300 ,
gs ,
gs300 ,
lexus ,
location ,
loose ,
position ,
recall ,
resistance ,
sensor ,
specs ,
throttle ,
tps
