Hid problems
Hi, i have installed a set of HID to my 1994 gs300, it worked fine for about 4 days, after that the right side will not turn on, i switche ballast to make sure everything was ok, i did not switch bulb, so i though the bulb was bad, so i ask for replacement, i changed the bulb but nothing, however when i turn the lights on it flashes but thats it, also i notice the high bean wont work, i havent take a deep look at problem, but any help will be appreciated, thanks
thanks, but what is the igniter? if it is the ballast i did change from one side to the other, and everything works just fine, except on that side, all it does is flash, later today i will take a look with more time, it looks so wear that the high bean is bad too...
minla007
03-09-07 08:20 PM
