are exhaust tips removable???
I found some nice 4 inch o.d. exhaust tips for my gs, but after looking at the existing ones, I'm not sure the existing tips are removable....... my expensive dealer service manuals do not even discuss the exhaust system at all... My 93 camry xls had tips that were removable with 3 small screws, but I do not see any on the GS. Well guys....... what can you tell me??? Thanking U in advance.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
hi marcus,
i tried to remove it but gave up - instead i had them cut off and the new 4" welded on...even the local dealer couldn't tell me how to remove them. btw don't forget to paint the welded area to avoid rusting after the install.
good luck,
geees
good luck,
geees
I appreciate that info... It does appear that these tips are welded on, after a closer look..... I am going to try to save the pipe and cut the stainless steel ovals off with a Dremel tool. How does yours look with 4 inch tips?????
