Rear spacers for our cars?
Yeah, I read that same post. Ok, to H&R's. They apparently come in several different types:
* DR Wheel Spacer (for 10-40mm track widening) is fitted between the wheel and hub, using longer wheel bolts (please order seperately).
* DRS Wheel Spacer with new longer studs supplied (for 10-40mm track widening) is fitted between the wheel and hub, exchanging the existing wheel studs for longer ones.
* DRA Wheel Spacer/Adapter (for 40+mm track widening) is fitted to the hub with special wheel bolts and has new threaded holes for existing wheel bolts.
* DRM Wheel Spacer/Adapter (for 40+mm track widening) is fitted to the hub with special nuts and it carries new wheel studs for the existing wheel-nuts.
The best pricing I was able to find was at http://www.optauto.com/webstore/prod...t=421&last=421
It looks like the only 25mm spacer type is DRM, which I am not too crazy about. I personally prefer DRS.
Originally posted by indypwr
why do you guys need wheel spacers for?
Ed
actually i want all 4. not just the rear. i don't want it to pop out like (nationality here) cars. i just want my wheels more flush with the body for the meaner look instead of being more under and inside the car.
so which ones are the ones we would need to buy. i'm kinda confused. i have stock rims and want about 1 inch around.
So you are set on buying them? If so, when can we expect to see pix?
i'm using 15mm out back and 5mm up front. i tried the 25mm in back at first but was rubbing like crazy. looked nice though. they are h&r. you will need to roll the fenders if you are lowered and using 25mm. you should only consider h&r, they are the only hub centric spacers. also for the most agressive look i would go 25mm in back and 15 or 20 in front if your rims aren't staggered.
1. stagger setup means like if your back rim are wider than your front, or if your just running wider tires in the back. you'll hear people talking about 8.5 inch rim in front and 10 inch in back. that is stagger. or 245 in front and 285 rear or soemthing.
3. as for your car being lowered. you don't have much of a choice if your budget is under 500. the only choice you have would then be eibach pro kit which is about 1.5 inch drop
My question though is, if you look at the pix of my car, does it need to be lowered or can I get away with the current look? Much like yourself, the $$$ is tight, and if I were to spend the dinero, I'd rather get the HID retro kit or the conversion like yours. Stock light output (or lack thereof) irritates me.
no kidding. my girl drives EXACT same car as me except her exterior is grey and mine is black. both our interiors are dark grey. its cool cuz everyone thinks its soo cute that we drive the same car
. but when i drive her car. the headlights are sooo dim. its not even funny. if you ever come to cali i'll let you drive my car then drive my girl car right after. its like night and day.
as for the stock struts handling the shorter springs its hard to tell. i remember 1 person here had there stocks shocks blow 1 month after installation. and others have had it for over 6 months with no problem.
as for the tire wear issue. thats my main concern for lowering my car right now. i have pretty expensive tires 150 a piece. michelin 225's. so i don't want to fezuck em up. it looks like you have 16 inch tires so it MAY be a problem. from my previous post it seems like if you have 17+ rims you won't have a problem with the tire wear issue. also make sure you know what its gonna all cost you before you start. like myself. i'm not going to do anything until i can buy everything and do it all at once. i don't feel like someone putting on my springs. and then paying them again when i want to put on my shocks. just do it all at once.
I have 17x7 rims with 225/50 all around. About the width, when I bought them, I just didn't know any better. I should've bought 17x8. But I definitely didn't want to go more then 17" cuz I live and do most of my driving in New York (hopefully you get the idea). That's why I am affraid to lower my car or to put on a body kit. The roads here suck. My friend got a 2001 IS300 with 17" rims and low profile tires, and he bent both of his front rims within first two weeks (he sometimes drives like a suicidal maniac, other times just aggressively).
I don't know if you notice, but the front tires look pretty flush with the fenders, but the rears could be pushed out 15-25mm, I still haven't decided which.
