car audio wire connector
Im new to this and really need help. Could anybody tell me where i can buy a car audio wire connector for my aftermarket radio the cd player is a pioneer deh 14ub
was it hard to do and how exactly did you cut it and also the radio that i have is a pioneer deh 14ub and it doesnt have as many plug ins as i do wire and antenna plugs in the stock wiring harnesses
no it wasnt hard to do...the diagram is easy to find. i just the radio out, cut only the necessary wires that i needed to, matched em up with the harness, and i believe i bought a cable for the antenna wire but im not completely sure.
i found the diagram and since the radio jack has to go into the aftermarket radio where does the antenna jack go do i have to rewire that too because the radio i bought only has one plug for the radio jack and not the antenna jack im just confused a lil bit on this, first time owning a car and first time trying to hook up a radio because i will not ride in silence any longer ish is killin me lol
i first took out the lighter/ashtray and then i took out the air conditioning vents then there will be like 2-3 screws that you have to unscrew thats holding the radio and the climate control in place they are like 15 mm screws i think and once you unscrew that make sure you unplug the wire harnesses connecting them
LovEnPeaCe
04-28-07 10:04 PM
