problem with cluster like everybody knows.
Been restorng my 95 Gs 300. For a. Time
Now but my pet peve. The. Needles so got my hands on some and when installed the speedometers and rpm took a. Dump Help don't kmnow what went wrong. Got power good ground. .
did you tighten the screws in the back of the needles up the right way? the long screws that go in the back are the ones that make a connection and if they're not tightened all the way you get no signal
if one of the screw holes is stripped, or the grounding screws isn't in the right spots, then it won't work at all
do you mean the ligths on the speedo and tacho don't work? or the needles don't move anymore?
Sorry haven't responded sooner but went to salvage yard and found one exactly like my 95 and removed cluster and installed new parts. And works GREAT 1ST TIME EVER FOUND ONE IN SUCH great CONDITION . The problem with mine the could around the parts were. Spun thhanks for your imputs
YeA 2jZ
SC- 1st Gen (1992-2000)
09-04-09 04:44 PM
Twix
12-15-08 04:18 PM
