gs300 tranny
hey guys im just wondering if the gs300 tranny is the same as the twin turbo 2jz aristo. Is the manufacturing/part number the same? im planning on doing a full tranny flush with toyota type t-iv fluid. the old fluid is type t-ii. i read in service bulletin TC003-99 that the old type t-ii should not be mixed with the new type t-iv. Because of this im planning on doing a full flush. Additionally, is the aristo filter easy to change and is it the same part as the gs300? and is the transmission pan gasket identical?
Thanks so much!
Thanks so much!
the transmissions are physically the same size and everything, but the difference is that the gs300 tranny uses a wire to shift and the aristo one shifts electronically
