gs 300 '93 aristo swap
Anymore pictures of the intercooler mounting? Specifically looking straight down from top. I want to see how close it is too all of the lines behind it.
Car looks great, and all of the pictures are cool too, have given me some ideas for my own project, thanks!!
For the intercooler support, I make to holes in the front aluminium protection from down to up, the down side need to use a biger bit drill, because need space to pass thru the tool to tie the nut from begin
fell free to ask any doubt or question tha you have
regards.
carlos
here some pic for the intercooler instalation
need to modify the piping support
the filter need to move it up, to clear the top of the intercooler
here is a pic of the bolt install it, in the front aluminium protection
so after few day of relax, waiting part to arrive, we can continue with some action
we receive the trany cooler and the exhaust pipes to finish the down pipe
the aristo engine, didn't came with the power steering container, so need to install a supra MKIII PS container :S we don't have to much space to install it :S
time to work in the exhaust system, the customer didn't want to change the existing exhaust system, so we need to connect the down pipe to the existing exhaust, let see what can we do
First we will cut the flange from the first catalytic converter
them time to build the piping to connect the down pipe and the exhaust pipe, it was difficult to do it, but not impossible
then time to finish the down pipe
Downpipe done
Time to install the transcooler
then, we need to install a electric fan, because the fan blades hit the ic piping
parts needs!
Custom bracket to install the fan in the radiator
i hope tomorrow will be finish
parts needs!
the electric fan its ready
this is the wiring diagram
When the ignition switch its on, the fan will run at low speed
Whet the temperature reach 200F, the fan speed will change to Hi
need to extend the temperature sensor harness, to have a better sensing
now the ic piping its done
a small vid
a small vid
