SQUEEEKY brakes
Originally posted by mcnelson
Ohh, ohh, I get vibration when braking sometimes. I hope that it is just my rear stock rotors that would be mucher cheaper to replace than my front Rod Millen rotors and pads. I guess I will have to replace the rear when I get the chance.
Originally posted by Sovero1
Since your front rotors are RMs, I think it's safe to assume they are cross drilled and slotted? I am curious if anyone has ever machined/resurfaced them, or do they just need to be replaced? As far as replacing the stock rotors, if they are not entirely worn out, just resurface them. Around $20/pair or per disk, not sure. But definitely cheaper then buying new rotors at $200+ for a pair.
Usually you could tell just by looking at them. Rear rotors even new will be thinner then the front ones, and more than likely not vented, since they only handle 20-30% of breaking. The best thing to do is to go to any auto parts store and look at generic rotors. They are all approximately the same thickness, especially if they are made for your car. This way, after 5 mins at the store you'll know whether or not the guys at the shop are telling you the truth.
Jmai22: Do you feel any vibration at all when breaking at high speeds or your brakes just squeal? If it's the former, your rotors may need resurfacing, if the latter, may be you need shim oil or maybe your brake pads are worn to the point that they need replacement.
When I bought my car, it'd vibrate when breaking from 80- mph. After resurfacing the rotors when changing brake pads the problem went away for about 2.5 years. Now the car started to shake (it's barely noticable) again, and when I will be changing the brake pads (I was thinking of going with EBC Green Stuff instead of OEM pads) I 'll have my rotors resurfaced again. I have stock rotors, not slotted, drilled or anything like that.
ALL: What does it mean when the rotors get warped? If I understand it correctly, it's uneven wear from the brake pads?
John, do you have stock brakes front and back or aftermarket?
