SQUEEEKY brakes
SQUEEEKY breaks
ok i so my breaks are still squeeking like before. i read from a previous post it could be due to break dust. is there anything i can do from keeping the squeeking from coming back. its pretty embarrasing. i can drive in a parking lot doing 10mph with my foot barely on the breaks and they make soo much noise help.
naw my car is perfect. only problem is water leak and my freakin breaks. remember that day we drove around with my car to get our headlights done?? and you said my breaks were loud?? its doing the same thing still.
steady squeek or on and off??
Jmai.... I had a squeaking noise that was on and off, on and off, when I applied the brakes, not a constant squeel.... My front rotors were warped, after installing new rotors, this cured the problem. if you have a steady squeel, I would agree that a different pair of pads might cure it.
Guest
Posts: n/a
If your car is pretty new, most likely whoever put the brakes on forgot to put 'pad oil' or whatever it's called behind the shims.
If you know yourp ads are new, then it's safe to get some anti-squeal' from your local auto parts store and apply it between the shim (thin metal piece that goes over the caliper) and the brake pad back. Do NOT put it on the part that touches the rotor. You won't stop very well.
Mot aftermarket pads are pretty quiet, but some are more nisy than others. So far after trying NAPA, and another nameless metallic pad, I've found Toyota OEM pads to work the best.
Guest
Posts: n/a
I don't understand how it works either.
It has something to do with the the horizontal vibration between the caliper and the brake pad.
The anti-squeal works, my NEW toyota pads and rotors squealed a day after I put them in, took the wheels and pads off and applied anti-squeal and poof no more noise.
Originally posted by Jmai22
how does this oil work if i put it between the shim and the pad.?? i don't see how the shim causes a squeeking noise since it doesn't move
there was this GREAT thread many months ago that i cant find now about brake squeal...very comprehensive. it came from someone in the SC forums. if someone knows what i'm talking about, raise your hand.
My stock rear brakes squeal sometimes too! I am thinking it may be that my rotors are warped, but how can you tell if that is the problem? I don't want to buy new rotors and then that wasn't the problem.
Originally posted by meZoom!
well if the sound of your squeaking gets "slower" as your wheels turn slower (slowing down basically), then your rotors are uneven. i think in your case, maybe get new pads?? they might be worn out. check shims and area around the sliding pins, maybe you could use some of the squeal stop stuff too.
Jmai22: Do you feel any vibration at all when breaking at high speeds or your brakes just squeal? If it's the former, your rotors may need resurfacing, if the latter, may be you need shim oil or maybe your brake pads are worn to the point that they need replacement.
When I bought my car, it'd vibrate when breaking from 80- mph. After resurfacing the rotors when changing brake pads the problem went away for about 2.5 years. Now the car started to shake (it's barely noticable) again, and when I will be changing the brake pads (I was thinking of going with EBC Green Stuff instead of OEM pads) I 'll have my rotors resurfaced again. I have stock rotors, not slotted, drilled or anything like that.
ALL: What does it mean when the rotors get warped? If I understand it correctly, it's uneven wear from the brake pads?
Ohh, ohh, I get vibration when braking sometimes. I hope that it is just my rear stock rotors that would be mucher cheaper to replace than my front Rod Millen rotors and pads. I guess I will have to replace the rear when I get the chance.
