Possible Fuse Issue!
Old 04-26-13, 04:59 PM
JSlaughta
JSlaughta's Avatar
Default Possible Fuse Issue!
Sup CL. My clock, climate control, and radio are all out. Nothing in the center is working. Could this be a fuse issue? If so, wheres the fuse for them? Any help would be appreciated.. thanks..
Old 04-26-13, 05:03 PM
DomRebel
DomRebel's Avatar
It's most likely a fuse issue, check the fuse box in the driver kickside panel underneath the steering wheel.
The are spare fuses in the fuse box underneath the hood, as well as the fuse puller which you will need
Use the fuse puller and check out all the fuses while you're at it, and replace the ones that have been blown (should be easy to spot the blown ones)
Old 04-26-13, 05:06 PM
JSlaughta
JSlaughta's Avatar
Thanks Dom.. Step out and check them now!
Old 04-26-13, 08:14 PM
Nixspeed
Nixspeed's Avatar
There are 2 possible fuses it could be. One under the dash and the dome fuse under the hood.
pentiumvi
RX - 4th Gen (2016-2022)
38
01-16-24 05:33 PM
ALLWiTE2JZ
SC- 1st Gen (1992-2000)
10-23-11 03:09 PM
spxChrome
07-10-06 04:54 PM
mcnelson
08-05-02 05:13 AM
Quick Reply: Possible Fuse Issue!
