Also I just thought if you didn't reset your ecu the codes will stay until a certain number of restarts with no issues. Easiest way to do this is to pull the (20amp) fuse from the fuse block in the engine bay labeled efi. Keep it out for about 10mins just to make sure all the capacitors are drained and it reset.
