Oil pump gasket....
Is there such a thing for 94? Anyone have any experience with this? Still chasing a leak in front of engine and am curious as to wether this cud be source.....thanks...
Thanks for responses....I have changed both cam and crank seals 3 times....(using suggested techniques from this forum) Both oil pan and valve cover gaskets are good....I used dye in the oil to help locate leal, but still can't exactly find it because oil is behind the cover, belt tensioner, crank pulley, and generally on front of both block and head when I dig out all the parts in front....
Btw...what does the front cover stop oil from?
My original question is asked again.....is there a gasket behind it that could be bad?
