Now the process begins
General update for everyone.
Wheels are now a dark grey (gunmetal almost)
Ive got a short ram air intake for the car, but it wont idle so its just got a cone filter on the end of the MAF
Ive sourced some suspension components, come tax season im getting stiffer springs, but only dropping it .5 inch
Sourced exhaust, im running hi flow cat, into 2.5" piping, split into Magnaflow street series dual mufflers.
Im receiving seat covers for christmas, so Ill delay getting the Corbeau A4 wide series for now
Sound system is fixed, im installing an amp tomorrow and running a alpine 10" sub with a kicker amp.
I may also look into getting some body work done but want to do an aero kit as well, nothing gawdy just a nice lip kit.
I was going to do the supra TT brake upgrade but i dont have the cash for new wheels yet.
Wanted to use my old thread to update.
I went to rewire the stereo. Well I patched everything back in and used a schose (spelling?) wiring adapter. Nothing. I guess since I'm not running the factory amp / cd changer it won't work. Back I go rewiring similar to how they had it. I still can't get the auto antenna to work nor does my HVAC still light up. I'm guessing since illumination isn't needed is what's wrong. All though when I hit unlock my HVAC lights up, so I'm thinking a short somewhere.
Once I find a power tap point in the trunk ill hook up a new amp and run a line out converter to my new amp until I get time to rip it all out and run RCAs and a new power wire.
Nixspeed, what did you tap into for power? I recall you said you used the factory wiring as power. Even though its a smaller gauge it will work for now.
Only factory wiring I used was from the OE amp to the door speakers. I'm running 1000w total so I needed much larger power wire as well as remote and rca from the new head unit. I also tried to use the adaptor which did not work. Ultimately I just used a volt meter to check for constant, switched and ground then ran everything else. It really is your best bet. The factory sub amp wiring is way too small even for 100w amp. If you use it you'll end up pulling too much current and risk burning your car down. I figured that out the hard way lol. Didn't burn my car down but melted a lot of my carpet in my old car long ago.
I used my VM too so I could get power. I used the stereo write up in the DIY sticky. Its grounded on the frame. Still can't get the antenna to work or the HVAC lights lol. But the climate control lights work hitting the unlock button so prob a short.
Time to break out the diamond tipped drill bit to run power wire lol ill prob run a line out converter until I have time to run RCA cable.
Alpine speakers coming soon and a 4 channel amp.
Can I get y'all help. I need to find stock Mk IV turbo wheels, the 17's. EBay is to expensive and so is Amazon. If anyone knows of any on Craig's list in your area shoot me a reply on here. I had procured a set here but someone went under me and beat me to it.
I've decided to do basic upkeep of the engine and I'm getting body shop quotes soon. My passenger side quarter panel is getting horrible so I'm going to have to invest about 3000 for a good paint job and body work.
Here is a link to the headlight sanding process(see post #1) and most importantly, the UV coating process so that you will never have to sand/polish the lights again.
http://www.autogeekonline.net/forum/...lant-idea.html
I did not do this sanding method, I used the 3m kit from the auto parts store. I worked great when I did this 6 months ago, but now I will have to do it again because I did not put on a UV protective coat at the end. I will use the same kit, but this time follow these instructions for creating the perfect UV protection seal.
Also I read that you are looking at a paint job. Have you thought of doing the body work(sanding, primer, and light smoothing sand) yourself? It may save you half the price and you can walk away knowing that you did a good job on the most important part of a paint job... the base. Youtube this stuff and you will see.
Hope this helps
Hope this helps
