I Need a 2jz swap specialist!!!
I ned to tow the car so im leaning towards a more local swap. Why the hell doesnt know anything about 2jz's in minnesota. MOUNTS, BELTS, GASKET KIT, BATTERY, TT WATER PUMP, THROTTLE CABLE, TURBO TIMER, BOOST CONTROLLER, INTERCOOLER, EXHAUST, single turbo conversion..pulley kit, cam gears, and whatever else needed....THESE ARE ALL THE THINGS I NEED ALONG WITH THE MOTOR AND TRANNY SET UP CORRECT? Man I sure hope 6k will get me out the door with all thats mentioned.
Battery is the same so you don't need on unless yours is bad. Don't waste your money on a turbo timer. Just don't full boost then shut it off. You don't NEED a boost controller from the start either. All of this can be added later after the car is up and running good. Get the supra TT cable as the Camry one is a tad long.
Good luck with finding a shop. Hard to believe there isn't one Supra shop up there.
