I Need a 2jz swap specialist!!!
Old 12-08-13, 09:29 AM
JadeAristo
JadeAristo's Avatar
Default I Need a 2jz swap specialist!!!
Are there any shops in Minnesota, Iowa, Wisconsin or the Dakotas who have done the 2jz swap in the GS300 and are reputable and trustworthy? I cant find anyone!
Old 12-10-13, 02:07 PM
jaymil31
jaymil31's Avatar
Default Re
What problems are you having
Old 12-10-13, 09:04 PM
Nixspeed
Nixspeed's Avatar
Seems like he just wants a swap done. If I was closer I'd help you out. That's all I specialize in are Toyota/Lexus swaps.
Old 12-11-13, 09:47 AM
Jostar
Jostar's Avatar
I hope I don't get in trouble for my post, ELITE AUTO CENTER in Plainfield Illinois, they can DEF help you out with the swap....
Old 12-11-13, 11:58 PM
JadeAristo
JadeAristo's Avatar
Where are you located Nixspeed? Thank you jostar I will look into that place.
Old 12-12-13, 12:01 AM
JadeAristo
JadeAristo's Avatar
How much would you charge for the swap nixspeed if I had all the parts needed?
Old 12-12-13, 04:59 PM
Nixspeed
Nixspeed's Avatar
I'm located in north metro Denver, CO. Pricing would all depend on how extensive of a swap etc. If you just want the aristo setup bolted in as is it wouldn't be too much, around $1200 to pull the old motor and install the new one. Now if you want me to replace gaskets and seals which I highly recommend and do custom single turbo, custom exhaust, etc it will go up from there. I also recommend getting a new harness like Tweakd supplies which I get a slight discount from and will pass along. I originally bought a jumper harness for mine but at least half of the connectors were broken or broke as I went to swap plugs etc. I also will have my turbo kit for sale soon that is bolt on for the jzs147 without hammering on your firewall like stock twins.
Old 12-15-13, 09:42 PM
JadeAristo
JadeAristo's Avatar
Do you own a shop Nixspeed or do you work out of your own garage? Do you think 5,500 cash would get the 2jz in with all new gaskets, belts, single turbo upgrade, custom exhaust etc? Can you get a 2jz for under 2400 for me? I would consider a road trip if all adds up
Old 12-16-13, 06:44 PM
Nixspeed
Nixspeed's Avatar
I could do custom ceramic coated single turbo kit, all new belts, gaskets on outside (main, cam, crank), with new mounts, and tune up. Turbo kit with dp will be $2500, motor and trans are about $1800, I suggest a new harness $1000 or less, intercooler and exhaust will be extra and can be done fairly cheap or expensive depending on what you want. I did my exhaust for $2500 in parts but it flows great and sounds great and looks great while being quiet. A lot of my extra money was spent on coatings and extra touches. Not needed but look and function better.
I had a shop for awhile but have been building most of my projects in my 2 car garage but I'm currently building a new house with a 2500ft2 shop. It will be done in June if all goes well. If you did want me to do it id have to wait till then as I'll be in a transitional period. It would allow you time to accumulate all the parts etc needed.
Old 12-23-13, 12:06 AM
JadeAristo
JadeAristo's Avatar
Okay I will keep in touch!
Old 12-23-13, 12:36 AM
Nixspeed
Nixspeed's Avatar
Sounds good. Either way let me know your progress and if you have any questions I'll try to help as much as I can. I'm on here pretty frequently. Plus there is always other guys that can add their 2 cents as well.
Old 12-27-13, 06:07 PM
JadeAristo
JadeAristo's Avatar
where can I buy a single turbo conversion kit for the 2jzgte that will go into my jzs147?
JadeAristo
JadeAristo's Avatar
Head gasket blew on my motor Christmas eve...yay!!!
Old 12-27-13, 06:09 PM
JadeAristo
JadeAristo's Avatar
I need a Minnesota shop!!!!
Old 12-27-13, 10:06 PM
Nixspeed
Nixspeed's Avatar
I have a single turbo kit for a 2jzgte in a gs300. Its all bolt in except from the dp back. That you'll have to fab up which isn't too bad.
Quick Reply: I Need a 2jz swap specialist!!!
