cams/ camgears for gs300?
sorry to say but you dont get 10-15 hp out of cam gears alone.
best combination wud be having a camshaft and cam gears, then you will get at least 15 hp and if you upgrade yr ecu, you might get another 10 hp from that.
i wz thinking of getting cam gears before. the ones that will work for 1st gen are from supra 1995 and up (non-turbo). JUN, HKS, UNORTHODOX cam gears will fit any 2jz-ge blocks. if you will only use cam gears, hp gains are very limited...........to say less than 10.
Since I have had my car stored this winter and haven't driven it much when I do go to drive it everyonce and awhile the gears squel for few minutes and then it goes away. Is there anything I can do to properly lubricate it so it doesn't do that. I don't want to just shoot it with WD-40, is there something specific I should use?
