1993 GS300 w58 swap A/T ECU
I am planning on doing a W58 swap with A/T ECU, I have heard that this will cause CEL codes because the ecu doesn't see a trans. Is there some sort of work around that will allow me to use the A/T ECU and not have it trip the CEL? I live in CA so I have to worry about this because of the smog checks.
thanks for any help.
Yea I have no problems running a R154 and my stock A/T ecu for the gs300. Check my thread for how I wired it
Yes. This is correct.
Awesome. This means I won't have to try and get an auto Ecu. So the only wiring involved is the neutral switch, reverse lights, and speed sensor right?
Speed sensor is already wired, just unplug and replug
