Stereo rundown
Stereo rundown
I know I've had a few individuals ask me some stereo questions. I wanted to post this to make sure I was right.
I have the Pioneer option not the other (not sure here guys on the other option)
4" speaker front doors with cross over to
1" tweeters in front door (they look more like 5/8 or 7/8)
4" speaker rear door
12" factory subwoofer rear deck
Im getting gathered information on factory specs. Amp was 55 x 4 with 125 to the sub. Right?
5.25 can fit in the doors after modifications?
You can not use a harness on aftermarket stereos unless you retain factory settings (amp and CD changer) you have to hardwire?
Reason I'm asking I'm normally asked stereo questions where I used to do competitions and was MECP trained to do installation.
Yes 5.25" will fit. I ran 5.25" components in front and 4" coax in rear. 4" coax are easy to find. You don't need seperates in back so just run them up front. I ran Focal all around with Excelon DVD in dash and jl 12w3 and 2-10w0 to round out the mid bass a bit. I've been doing car stereo competitions and was mecp certified and this is by far the best sounding stereo I've ever heard as far as clarity and volume.
My sq was awesome but when I wanted to thump I turned down the gain on the speakers and cranked the gain on the subs. Lol I made a custom panel under my mp3 player, since cressida are double din like us I ran a single din deck with 2 ***** and 2 switches under the deck. The ***** for the gain, one switch for the subwoofer amp, and one for my fog lights.
You can run 6.5" door speakers if you cut cut your own baffles. Much more worth it if your going to remove stock speakers. It's a PITA as new speaker wire must be ran from your external amp but well worth it. I don't miss my stock HU one bit.
I got my new setup in. Kicker 4 channel, 100x4 amp. HiFonics 5.25 components up front, 4" HiFonics coaxial in back, and waiting on my alpine type S subwoofer. Until then I'm running a Memphis 10" in a ported box on a kicker 600×1 mono amp.
I rewired the factory enclosures for my aftermarket speakers and even hid my crossover inside the front "boxes" and I removed the stock trunk mount amplifier and replaced it with aftermarket and just reused the OE wiring. It is not ideal but mine sounds great. You're not going to push much power to s 4" or 5.25" anyway so the OE wire is plenty big enough and ran rather clever as to avoid interference.
If you need help with yours I can help you out or if you just want to see/hear mine.
Yet another thing we have in common bro. Lol I did Db drag for years. My highest spl was 149.6 in a 5 speed cressida (rare as hell and I miss her every day.) I ran Audiobahn flame q DVC 12's, 1800 peak 1000 rms at 2 ohms on a BOSS 2000 watt amp. About matched my ohm load and RMS. I ran a kicker 4 channel, 125x4 on my speakers. Memphis m class 4" components up front with my tweeters on the door sill with Memphis coaxial 5×7 in the rear.
150 is no joke. We hit 158 back in '98 with 1 cerwin Vega stroker 15 in a Ford probe. I'm too old for that stuff now lol. My stereo gets quieter as does my exhaust.
I'm looking at a Alpine type S for replacing my factory sub on a HiFonics amp. My mind kept changing on the factory sub until I compared it. You don't even hear the subwoofer flex. Just clean, tight bass
