"Braking" question
O.C. Lucky Strike Fanatic
Hi guys,
I replaced my brakes about 2 months ago and did not hear anymore squeeks. Until last week I started hearing it again and decided to see my mechanic. He took out my rear rotors and resurfaced it. The squeeking has gone down tremendously and I am happy.
However I still hear a lil bit of sqeeking sounds. My mechanic says I should change the way I break. In that I usually brake a little bit and then release the brake and then step a little more to a slowing stop. He recommends me just stepping on it and not depressing until it stops. WHat do you guys think? The sqeeking sounds are pissing me off because this car aint cheap and shouldn't be doing this... P.S I also posted this in another forum for more responses.
thanks
Bryan
thanks
Bryan
i have the exact same problem under 30 mph it would squeek. like a contant whistly like squeek. but over 40 its fine. also when i actually press the brakes it makes no noise. only when i drive under 30 without pressing the breaks. i find that break dust build up causes most of the squeeking.
btw what kind of pads are you using? i'm using the ones they sell at kragens.
jmai.. i remember you mentioning this in a thread before. has anybody thought of a solution to this problem? this happens to me all the time... i don't mind it right now, but it's pretty embarassing in the summertime...
a few member suggested that i go buy this gel at the counter of auto part store and put that gel between the shim and the pad. haven't tried it yet. anyone else have?
I was told by someone I consider very trustworthy in stuff like this that the rotors on our cars should not be cut.....that it will just re occur in a short time....which seems to be what is happening to you guys. I replaced all my rotors and all my pads when I bought the car. I got them at wholesale and paid $30 for bendix import quiet front pads, 27.99 for bendix rear pads, $91 bucks for each of the Brembo rear rotors(they were out of Bendix but Brembo is just as good) and $120 for the front Bendix rotors. I just figured I would do it all at once and get my brakes outta my mind for a while.....I took advantage that I had the cash cause if I wouldn't have done it then I would have spent it on something else which would probably turn out to be much less important thna brakes.
anyway....just my 2cents
Originally posted by DTPstyle
A friend of mine told me that if I used carbon brake pads, there would be no noise. The fact that I used semi-metallic is the main problem....
Bryan
Bryan
Also, whenever you turn the rotors you need to replace the pads as well, even if they are not completely worn. Because if your brakes are squeaking because of the glassy appearance/effect on your rotors that same glassy effect is found on the pads so they will still squeak.
Buy the organic pads, if you havent driven much you may not need to turn your rotors again (here i can get them turn for $5 per rotor)..You can only turn them a few times before you fall below your min. thickness of the rotor.
Well no, i don't actually know the life span comparison. And i have never tracked mine, just replace them when i need them. However, the semi-metallic are going to squeak. So you can squeak for say 20,000 miles or ride smooth for 15,000miles.
Do your new brakes perform better than the originals (stupid question, but I have to ask)? Do you ever hear any squeaking? Are the new rotors slotted, drilled or dimpled?
Originally posted by Sovero1
Alex,
Alex,
