Front crank seal?
this will get you started off.
To break the crank pulley bolt loose, Place a socket/wrench on the bolt, use a breaker bar on the socket. Place the breaker bar on the floor or in a snug spot where it won't spin. Go in the car, turn the key for a milisecond where the starter turns the engine and snaps the bolt loose. DO NOT HOLD THE KEY IN THE ON POSITION OR THE SOCKETWRENCH/BREAKER BAR WILL TURN YOUR ENGINE BAY INTO SWISS CHEESE.
incharlest
04-18-13 11:05 AM
