ac problem tx heat!!!
Did a full vacuum and recharge on my ac. The problem is my ac will blow cool when initially turned on but then goes hot. The system passed the leak test so it's hold the pressure, but there's no cold air. I was thinking fans maybe???? Or bad compressor even though it seems to work.
Is it possible to have 2 low pressure side lines?
The top pic is the front of the car. The bottom pic is exhaust side near fire wall. Never mind the freon residue do to improper connection of the ac machine smh.but anyways I wanted to know what the low pressure line is under the high side hose.
You say your AC starts out cold and then goes warm. Over what period are we talking? Right away or 5 minutes later? I have lost the ability to post pics so I would have posted pictures of mine last Saturday. I don't see the extra line in your pictures you are referring. Could you draw a line to the part in question?
If you can post a picture of your water control valve. It is located on the back of the firewall driver's side, just inside the Master Cylinder.
I think I have a bad relay for my fan. The extra low side fitting is in the same pic with the big red H. It sits right in front of the condenser. I'll def check that water valve u were referring to aswell.when my ac is on it'll run cool for about 3 mins then goes hot. My compressor never turns off ethier. Which would point me 2 believe my fan isn't kicking on.
