93" gs300 help
You my friend, need to be directed to my swap thread.
As far as wiring is concerned, I had Mark @ panicwire do the jzs161 wiring into my jzs147, its quite complicated and I showed pictures of whats involved in my thread but haven't been able to do the pinouts myself to share with others. I could share with you the ECU pinouts of both motors and you could see how mine was connected but it is quite a lot more work than a a non vvti motor (BUT SO WORTH IT!)
luxury-performance-jzs161-motor-and-jzz30-r154-5-speed-swap
As far as the down pipe is concerned. I cut the flange off my stock header after the cat and ordered an Aristo flange from drift motion to create my own down pipe. I think this is pretty much your only solution, but it wasn't that hard and I did a chitty job.
4rcedfed
Performance
03-28-14 11:20 AM
