found some oil leak under distributor
john, ur such a playboy, man.....!!.......you he-******!!...ha.h.ah
dont blame yah, i wz like that on yr age!!....
ERIC/JOHN: yeah, let's all meet up to fix this problem. h.ah.aha...!!!...john, you found some oil leak also? that's really funny, bro. i called the dealer tody and thy have the gasket for under $5. you guys pick one up soon or whenever ur ready. im picking mind today after work.
DISTRIBUTOR: it shudn't be too hard to take it out and putting it back. dont worry, eric, like i said i have the bible for our cars at home. what i know, though, before we take it apart, the motor has to be at TDC,
top dead center. we'll have to see. if we do meet up, let's make it next wkend. ill be busy working on my jdm headlights and projectors.
just an update. my dad opened up my ditrubtor today and its super dry inside. so i have NO oil leak. thats a good thing. but my rotor is worn out in the middle of the ditrubtor so if i change it i should get more power.
As far as the rotor, you will only gain back the power you lost from the worn-out rotor. Since we will be working on the distributor, might as well buy a new cap and rotor if they are worn out. Those parts aren't expensive.
Originally posted by 007
hmmm.. okay, i have never had the o-ring to go out and man do i put miles on my car. But this may be because when i install a oil filter i put a little oil on my finger and rub it around the seal on the filter.. kinda like lubricating the rubber seals. I was taught this as a kid and have always done it. But you may do the same, so it just may be some more of that "weird stuff"
So i hsould buy a new cap too?? cool. i'll go recheck where the distrub connects to the head later
