Amp Power Wires
Old 04-09-15, 09:38 AM
TRACKMKIII
TRACKMKIII's Avatar
Default Amp Power Wires
I am in the process of installing an aftermarket Amp and Sub combo. I am just wondering how you guys are running your power wires? It looks like the only way is to run the wire from the battery along the drivers side across the engine back to the passenger side and then through the firewall? I was hoping to run the power wire only along the drivers side so I can keep it away from the RCA cables that I am running along the passenger side. Thanks in advance for any info!!
Old 04-10-15, 10:55 AM
williamb82
williamb82's Avatar
I ran mine through the hole in the inner fender under the fuse box like the body harness does, up through the bottom of the drivers fender(removed the plastic shield in the fender well to do this, then replaced it afterwards), pushed it through the same hole as the body harness into the drivers kick panel, used a metal coat hanger as I recall, then pulled it through the inside, under the carpet to the back, pulled the back seat and there was a big grommet behind it on the driver side I punched a hole through with a screwdriver and into the trunk it went. 4awg wire. Through the kick panel was a bit of a pita, but once done it was a nice clean install and the wire is as short as possible.
Old 04-10-15, 08:03 PM
TRACKMKIII
TRACKMKIII's Avatar
Awesome thanks for the info!
Old 07-19-15, 10:51 AM
kene
kene's Avatar
Default Thanks for the explanation.
I am about to install an amp as well. Thank you for this information.
Old 08-03-15, 07:50 AM
TRACKMKIII
TRACKMKIII's Avatar
Finally got around to running a power wire like described above. It came out really clean but getting the wire through that hole was a PIA!!!!!! I used the 3 white clips that hold the factory harness in place to hold the power in place as well.
Dx3
05-15-08 07:11 PM
oaltairao
05-22-07 08:32 AM
Kibble
04-04-07 08:08 PM
NineFiveGS
09-10-06 11:14 AM
Dx3
07-14-04 10:03 PM
Quick Reply: Amp Power Wires
