How do I turn traction control off on 95 GS300?
Old 04-05-03, 06:30 PM
Och
Och's Avatar
Default How do I turn traction control off on 95 GS300?
I can't seem to find any switch... Although, among the lights that are on the dash, there is one that says "Track Off" or something... I just dont know how to turn it on.
Old 04-05-03, 08:50 PM
Jmai22
Jmai22's Avatar
its optional. just because there is a light for it on the cluster does not necessarily mean you have TC.
Old 04-07-03, 08:41 AM
gompka
gompka's Avatar
yep if you do the switch should be on the right side right under the gauge cluster.
Old 04-07-03, 09:13 AM
Och
Och's Avatar
so i dont have TC?
Old 04-07-03, 10:05 AM
Pianoman72
Pianoman72's Avatar
Welcome to the club!
Be careful in bad weather because the back end is pretty loose.
Originally posted by Och
so i dont have TC?
Old 04-07-03, 03:31 PM
007's Avatar
The good news is, you have solved your problem, since the traction control was never on. I have it and love it.
This is what you should see:
Attached Thumbnails How do I turn traction control off on 95 GS300?-traccontrol1.jpg
Old 04-07-03, 03:36 PM
007's Avatar
Also the engine compartment will look like this:
Attached Thumbnails How do I turn traction control off on 95 GS300?-tracengine.jpg
Old 04-08-03, 07:01 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
I dont have TRAC either, I think they should not even sell this car without it, the back end is way too fishy!! I once spun 90 degrees left, then right, then a complete 180, on some sleet!! I know the negative rear camber and 20" low pro rubber does not help but still!! be very careful on ANY slick surface, and if your car is modded like my own, BE VEEERRRRYYYYY CAAAAUUUTTTIIOOOUSSSSSS!!
BTW- I was doing about 35-40mph when I had my ordeal, I thank the Lord, no one was coming, my life would have most certainly been in jeopardy!
Old 04-08-03, 09:30 PM
007's Avatar
On icy roads with low profile tires the traction control doesnt help much.. so you aren't missing much there.. But it helps a lot in rain, thru puddles, in turns, and over bumps at high speed. You know when its working cuz the dashboard lights up "Trac". In rainy weather it will light up often. Also when your tires wear down it will work often then helping you to keep control.
Old 04-08-03, 09:54 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Does anyone know if my 1994 Gs has traction control??
Old 10-17-15, 11:09 PM
OGgs300
OGgs300's Avatar
I know the 00 gs have the VSC button which is disable the traction control
DiverseIS
06-30-19 04:36 AM
flattire
Performance
18
10-17-13 03:46 PM
vietstuh
Performance & Maintenance
14
06-01-06 09:20 PM
BlackoutGS
05-18-05 11:36 PM
Quick Reply: How do I turn traction control off on 95 GS300?
