Overheating 94 gs300
Old 09-22-15, 08:32 PM
2jz510
2jz510's Avatar
Default Overheating 94 gs300
Can any body help me my gs300 heats up i changed everything in the cooling system and still heats up
Old 09-24-15, 09:04 PM
TheMole
TheMole's Avatar
What does "everything" consist of? Did you do it yourself?
Old 09-24-15, 09:19 PM
2jz510
2jz510's Avatar
Thermostat , radiator , all 3 tempeture sensor/switches fuel pump
Old 09-24-15, 09:24 PM
TheMole
TheMole's Avatar
Assuming the cooling system was bled correctly, have you tested if the fan clutch is working properly? Also, does it heat up at any driving speed? Hopefully not a blown headgasket .
Old 09-24-15, 09:28 PM
2jz510
2jz510's Avatar
Yes i let it iddle and after some minutes ot starts heating up yes the fan works and i dont think theres any head gasket broken.
Old 09-24-15, 09:35 PM
TheMole
TheMole's Avatar
Does it heat up at higher speeds like on the freeway? You can test the fan by trying to spin by hand while the engine is off. There should be some resistance when trying to spin it. If it's easy to spin then it might be failing.
Old 09-24-15, 10:32 PM
2jz510
2jz510's Avatar
No only when i exiting the highway thats when it starts heating up
Old 09-24-15, 11:34 PM
ArtME
ArtME's Avatar
Check oil if it is white then its a bad head gasket
Skegeemon
05-13-13 11:21 PM
gcam77
12-08-11 10:00 PM
2jzgttegs
10-13-11 11:03 PM
RedSC
Maintenance
03-15-10 08:28 PM
Quick Reply: Overheating 94 gs300
