Wierd wire found?
That could definitely be your short!!! Looks like the T-tap was to small and cut through that green wire which left it exposed and it probably comes in connect with me and creates a short to ground!! Remove that T-tap and splice the 2 halves of the original wire together again and I am willing to bet that it will stop blowing that fuse.
Awesome. I'll find out tomorrow when I finish wiring the oe radio in. But would this also cause my alt to work. I took the alt in to autozone and they tested it as good but it's not sending juice to the battery
Decided to just finish it tonight. Got everything cleanly wired in. Put a new fuse in and connected the battery...everything came on as it should...for about a literal minute. Fuse blew again.
I'Lloyd check under the knee panel tomorrow but I'm bring close to just taking it in to a mechanic...
