Brake Light
The light is most likely indicating that your brake fluid level is low. It is probably right at the minimum line in the reservoir right now, so under hard braking or cornering, etc. it will read below the minimum. Add some brake fluid and the light will not light up anymore. The lower brake fluid level is normal as your brake pads wear.
Cruisin101
01-23-18 01:16 PM
