94' gs300 Dies while driving HELP!
Old 11-19-16, 07:55 PM
stina
stina's Avatar
Unhappy 94' gs300 Dies while driving HELP!
Hi, so my car will start no problem when the engine is cold, after car is regular operating tempeture the car will randomly die as if someone turned the key off... no sputter nothing just on then off. So this is what i have done thus far: replaced the distributor, the coil, and the ecu already. tired of throwing away money any insights would be appreciated.
Last edited by stina; 11-19-16 at 08:17 PM. Reason: delete because i accidentally posted twice
Old 11-20-16, 10:00 AM
Mandrake
Mandrake's Avatar
If the car has problems when its hot, you usually suspect a bad coolant temperature sensor.
Old 11-30-16, 12:43 AM
3tcpower
3tcpower's Avatar
Does it start right away when you try to start the car after is stalls? Check for codes as well in sure the ecu is causing this issue. But check the codes first then post them here
Old 11-30-16, 07:33 PM
TheMole
TheMole's Avatar
Does it die when you are braking or using your turn signals?
Old 01-09-17, 10:08 PM
DanStarc
DanStarc's Avatar
Sounds like your Fuel Pump ECU is failing. You should do the relay mod:
http://mkiv.com/techarticles/12v_mod/12v_mod.htm
ErikTande
06-03-17 07:27 AM
stina
01-29-17 07:04 PM
Geechy
09-25-11 02:34 AM
LadyLexxxi
Performance & Maintenance
19
02-07-10 11:02 PM
huddleston
SC- 1st Gen (1992-2000)
09-21-09 07:07 AM
Quick Reply: 94' gs300 Dies while driving HELP!
