1993 gs300 can't get trunk open
Old 02-25-17, 01:49 PM
LouisM
LouisM's Avatar
Question 1993 gs300 can't get trunk open
Ok so after getting the gifted car (93 gs300) running I'm needing in the trunk. The problem is the security lock is on and I don't have that key appently. The keys were broke off in the ignition and it was changed. So the keys start the car but don't unlock the doors. I have a electronic key with the button that will unlock the doors but won't fit any of the locks. Any help appreciated
Old 02-25-17, 05:15 PM
TRACKMKIII
TRACKMKIII's Avatar
You can have a Locksmith match the locks to the key you have so you will have one key for the entire car or you can have the dealer cut a key according to your VIN that will work for the locks on the car but not the ignition.
Old 02-25-17, 06:16 PM
LouisM
LouisM's Avatar
The sad thing is the previous owner has 2 more keys that should open the trunk and unlock the security lock but god knows where they are. Really hoping for something cheap I can do really I just need to get his stuff outta their. Is their away around the security lock so I could use the button?
Old 02-25-17, 10:00 PM
TheMole
TheMole's Avatar
https://www.clublexus.com/forums/gs-...aster-key.html
https://www.clublexus.com/forums/gs-...-96-gs300.html
Old 02-27-17, 04:11 PM
jottinger
jottinger's Avatar
I seen this for a sc but if you can get to the lock some way maybe you can unlock it and be able to use your switches again
https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3D2FITcrUPKXw&ved=0ahUKEwj95ZCZvrHSAhVjiVQKHaklDqgQwqsBCFswDQ&usg=AFQjCNF4HsSPYAA9u7el_ALZsk9P-YS6IA
First time Ive tried to post a link I hope it works
Old 03-15-17, 05:17 AM
LouisM
LouisM's Avatar
Ok sorry haven't had time to repost on this issue. Got the trunk open. I pulled the security lock out and pressed the button on the back. Lock unlocked and trunk opens great thanks guys
xMUZZx
09-19-21 12:23 PM
Chione
14
04-20-20 04:46 PM
GeorgeG5
07-17-17 01:02 PM
xxmariolxx
04-23-14 04:15 PM
SC400slide
11-29-12 10:50 AM
Quick Reply: 1993 gs300 can't get trunk open
