how to clear rear taillights **PICS**56k DIEE**
Old 06-09-03, 10:40 PM
Jmai22
Jmai22's Avatar
Default how to clear rear taillights **PICS**56k DIEE**
man i just finished doing a write up and it all disappeared when i submitted because i used too many HTML codes. last year i cleared my rear turn signal but i accidently cracked it so i decided to buy one from a junk yard and redo that side. well i finally got around to it so i decided to do a write up since i got a camera couple weeks ago and i'm so excited with the new camera.
first pic is of the new headlight from junkyard
Jmai22
Jmai22's Avatar
back with lights removed
Old 06-09-03, 10:41 PM
Jmai22
Jmai22's Avatar
start heating up the flat side first, once you get a small opening stick a screw driver in it to create pressure while yuo continue to heat
Jmai22
Jmai22's Avatar
once the opening gets bigger stick screw driver in deeper to make hole bigger and more pressure
Old 06-09-03, 10:42 PM
Jmai22
Jmai22's Avatar
once you got the lens seperated it will look like this
Jmai22
Jmai22's Avatar
close up of the lens
Jmai22
Jmai22's Avatar
remove the frame. it just pulls up
Old 06-09-03, 10:43 PM
Jmai22
Jmai22's Avatar
see how easy?
Jmai22
Jmai22's Avatar
under is just a light distributor
Jmai22
Jmai22's Avatar
pull up on the light distributor it comes right off too
Old 06-09-03, 10:44 PM
Jmai22
Jmai22's Avatar
under you got the orange piece that makes orange light no matter what color bulb you put in
Jmai22
Jmai22's Avatar
remove screw from both side of orange piece
Jmai22
Jmai22's Avatar
gone
Old 06-09-03, 10:45 PM
Jmai22
Jmai22's Avatar
WALLAAHH
Old 06-09-03, 10:52 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Nice but wont the bulb be really bright? You will see the light bulb inside during the day.. illl...
Quick Reply: how to clear rear taillights **PICS**56k DIEE**
