What would work for this?
Well if you want to keep the offsetted tip look (to use the stock hanger points), then you can go with the Stainless Steel (or standard) oval mufflers and then just add some tips (magnaflow sells tips too).
www.magnaflow.com
Universal Stainless Steel Mufflers...
http://www.magnaflow.com/02product/ss.htm
Universal Aluminized Mufflers...
http://www.magnaflow.com/02product/universal/oval.htm
Double Walled Tips...
http://www.magnaflow.com/02product/tips/doublewall.htm
You'll have to look at the engine side of the mufflers to see if you have a offset/offset muffler or a offset/center muffler....
www.magnaflow.com
ok, here's the deal with the magnaflow mounting. you can go with the stock hanger points but the exhaust tips will be in to much. so you have to remove the tow hooks and have the mufflers welded back a bit toward the rear of the car so it can look right. it's not just plug and play so to speak. but very dueable.....
I think if he uses a 7.25" tip and have the muffler mounted as far back as possible (towards the bumper, but not too close!), it should be ok....how long is the stock tip from the very outer tip to the part where it actually goes into the muffler?
O.C. Lucky Strike Fanatic
www.magnaflow.com
www.magnaflow.com
