Need help with 2jz swap
Old 03-28-18, 08:45 AM
4drsupra14
4drsupra14's Avatar
Default Need help with 2jz swap
Since my motor is a non vvti ge is it easier to buy a 2jzgte non vvti than a 2jz vvti. I’ve herd that a non vvti is basically a plug in while the vvti one you need to run extra wire cuz my car didn’t come vvti so basically my question is if I buy a non vvti do I have to run any extra wiring?? Please I need help
Old 03-29-18, 12:29 PM
joewitafro
joewitafro's Avatar
Do you own a gs300 yet? Not sure if you have done any research because this has been posted on here a lot. You can use the search function or check the build threads for info on these swaps and learn everything you need.
Old 05-29-18, 11:39 PM
mobes
mobes's Avatar
Hate to be the one to say it, but if you're worried about running an extra wire, then maybe an engine swap isn't your cup of tea.
Allchets
03-10-20 01:39 PM
UncleRico
06-18-13 04:19 PM
Gs300chino
Performance
02-15-11 06:36 AM
bangski
Performance & Maintenance
15
09-04-06 06:42 AM
pass1914
09-15-05 03:35 PM
Quick Reply: Need help with 2jz swap
