ABS codes
ABS codes
Hi,
I have a 1st Gen Aristo with the ABS and brake light on. Before I go and replace the BMC for another used one, I would like to check the codes to rule out it's not and ABS sensor problem of something simple.
I would think the 1st Gen GS300 codes are the same, but I couldnt find them anywhere online and I also searched the forums. Can someone post the fault codes and explanation of the ABS system?
Thank you very much.
I checked the codes and here's what I got:
11, 51 and 54
I took the negative battery terminal off and here's what was left after that:
51
According to above it would be "ABS pump motor is locked" " Open in ABS pump motor ground"
Anyone know if the Aristo 1 Gen codes are the same? That could sound like the BMC as it has the ABS, right?
11, 51 and 54
51
