Power Steering Fluid
10th Gear
The repair manual for my 1993 GS300 specifies ATF-Dexron II for power steering fluid. Since it is no longer made, what is currently recommended?
Valvoline Maxlife Dex/merc, you can find it at any walmart.
Or Toyota 00718ATF00 dexron II/III which you can get at any toyota dealership for about 12 bucks a quart.
LIJoe (06-02-19)
10th Gear
Thanks, Joe. I knew you would know. Went with the Valvoline. I replaced the fluid in the reservoir using a turkey baster fitted with a 3" extension tube to be sure I reached the bottom. Even though the old fluid was dark brown, I hadn't been experiencing any problems. Glad I finally got to change it.
Cant hurt to add some clean fluid in there. Glad you found some.
