My car won’t start
My car won’t start
I have a gs300 and I can’t get it to start I changed my filters got a new maf and a new battery still won’t start still just keeps trying but never cranks it almost did then stopped can some one help me plz
Jakthedog (04-09-20)
Well there was oil around my spark plugs I haven’t finished pulling off my intake Manifold to get to the rest of the spark plugs would this be the only reason I am miss firing or would there be more to it then that
Watch out for the coolant line connected to the throttle body going across the valve covers, it can cause a big mess right in your spark plug galley when you try to pull it off. Yes, this can definitely be a large reason why you're mis-firing; you could also need new spark plugs/wires/cap&rotor. One of my spark plug boots completely ripped when I tried pulling it off, and I also had the same issue with the valve cover gaskets leaking. Make sure to replace the valve cover washers along with the gaskets to get the proper seal.
Jakthedog (04-13-20)
Mass airflow sensor
My mass airflow sensor was bad with same issues. You would have a find a used one on eBay or junkyard perhaps. It makes the engine run real rough and won’t start and throws everything off until replaced. Two screws and one connection right on top of the engine.
