18 wheel offset
![](https://cimg4.ibsrv.net/gimg/www.clublexus.com-vbulletin/960x720/11140750_1040377642646924_5462489063750390462_n_zpsceoljnkk_09f59494b4d87990706c65088a75dc2fba025daf.jpg)
This is running a 18x10 +25 with a 285/45/18 tire.
Running a 18x10.5 +22 would have 3.35mm or .13" less inner clearance, and poke outward 9.35mm or .36" more. I don't know if .13" would hit on the inside but I'm assuming no, but I think your bigger issue is sticking out another .36", there is no way you'll be able to "tuck" the rim without excessive camber, or run it like I do and you'll probably be fine with rolled or cut fenders.
RA641UZ (02-02-21)
