Loose shifter key removal trouble
I am looking at a 1992 Aristo in the states with auto transmission. The seller states that the shifter is slightly loose and sometimes when you put it in park the key does not release from the ignition so you have to apply some pressure to the shifter assembly for the key to come out. I was wondering if this is a common issue. Thanks
cmanES350
ES - 5th Gen (2007-2012)
03-03-21 05:57 PM
ToySC
Performance & Maintenance
10-11-17 10:38 AM
