Blow off valve location
Old 09-28-21 | 01:49 PM
fll2atl's Avatar
fll2atl
Default Blow off valve location
Yo I need some advise, I'm almost finished with the build, my question is should the blow off be on hot or cold side or does it even matter?? I'm thinking it will release the excess regardless of position. Just need some guidance here, thanks!
Old 09-29-21 | 08:40 AM
joewitafro's Avatar
joewitafro
I've seen it done both ways, you just don't want the boost to be hitting your throttle body when you let off the gas right? As long as you have an adequate sized blow off valve then it will discharge the pressure. I've seen them welded to the throttle body where the TRAC valve used to be on USDM supras, and you can see how I did it with my build below. I'm re-circulation because I'm using the stock JZS161 2jzgte vvt-i ecu which requires MAF/MAP and will die when you get off boost if it doesn't see that unmetered air.
Old 09-29-21 | 05:56 PM
fll2atl's Avatar
fll2atl
Thanks for your input fam. The info provided on this site has been informative. I will post the details of the build once it's done.
Rickna
General Classifieds
09-12-17 02:34 PM
tedsterb
03-03-17 05:49 PM
kinch09
Performance & Maintenance
03-29-13 07:08 PM
lexfrmtx
03-25-11 04:51 PM
jonny2k
08-24-10 06:00 PM
