97 gs300 tranny swap
1st Gear
Anyone know what i would need to swap my a350e transmission for a a340e transmission or just manual swap it for a r154? I have a 97 gs300 and the a350e has been slipping, im in high school still so i don't have a lot of money and just want to get the car running right again
Offley94GS (01-19-23)
A340E (30-40LE)[edit]
The detachable bell housing, which attaches the main transmission case to the engine, has an engine-specific bolt pattern, which appears on its upper surface as cast-in letters. "J" indicates the straight-6 1/2-JZ engine, "U" the V8 UZ engine.Applications (calendar years):
- 1987–1992 Toyota Cressida (30-40LE)
- 1986–1993 Toyota Supra (MA70)
- 1986–1992 Toyota Supra (GA70)
- 1990–1993 Toyota Supra (JZA70)
- 1993–1996 Toyota Supra (2JZ-GE) (JZA80)
- 1990–2000 Toyota Chaser/Mark II/Cresta 2.5 (1JZ-GE)
- 1995–2013 Toyota Tacoma 2.7L I4 (2WD), 3.4L V6
- 1993–1995 Toyota T100 3.0L V6
- 1993–1998 Toyota Previa 2.4L w/supercharger
- 1991–1997 Toyota Aristo (2JZ-GE)
- 1992–2000 Lexus SC 300
- 1992–1997 Lexus SC 400
- 2008–2018 Toyota Comfort (TSS11) (TSS13)
- 2008–2018 Toyota Crown Comfort (TSS10)
- 1990–1995 Toyota Crown Majesta 3.0L I6
- 1999–2003 Toyota Crown Athlete V (1JZ-GTE)
- 1991–2000 Toyota Soarer (JZZ30)
- 1990–1994 Lexus LS 400
- 1989–2003 Toyota 4Runner (4x2) (30-40LE)
- 2001–2004 Toyota Sequoia (4x2)
- 2000–2004 Toyota Tundra (4x2)
- 2005–2007 Toyota Commuter 2.5L
- 1985–1995 Toyota Pick-Up 3.0L
- 1990–1994 Volvo 960 3.0L
- 2004–2009 Isuzu D-Max (4x2)3.5L V6
- 2004 Isuzu Rodeo 3.2L V6
- 2008 Isuzu d tec 3.0l 4x4
A340E (30-40LS)[edit]
OEM with 2JZ-GTE twin turbocharged engines only. This is the twin turbo only heavy duty version with some internal mods. The main case is similar to the common A340E but not interchangeable, the bell housing has "J3" cast into the upper surface, and is larger diameter to accept the larger torque converter and special flex plate. Maximum power using the stock internals should be limited to 500 (significantly higher than the standard A340E used with the 2JZ-GE normally aspirated engine)[citation needed].Applications (calendar years):
- 1997–2002 Toyota Supra RZ (JZA80)
- 1991–1997 Toyota Aristo 3.0V (JZS147)
- 1997–2004 Toyota Aristo V300 (JZS161)
- 2004 Isuzu Axiom 3.5L V6
- 2004 Isuzu Rodeo 3.5L V6
