Sloppy rear end
6th Gear
Sloppy rear end
My first time making a post in here, very recently I’ve been having an issue with my gs where the rear end seems very sloppy, and likes to kick the rear end around when going over the line In the road or by just driving over a groove in the road.. and seems to skate around corners with just an all around sloppy feeling back there, any suggestions/advice?? Please help!
(car is lowered and on wheels, has been on a lift and everything seems very tight. I’m lost here guys)
How many miles are on the car? I'm approaching 300k miles and inspection underneath showed driveshaft bushings with mild cracking, subframe bushings are cracked etc. Obviously things like these generally require dropping the subframe so chances of them being done already are rare.
This usually happens when the alignment is out. I guarantee your rear isn’t all in the green. Also the knuckle bushings were making my rear feel loose and sloppy. Felt like a bmw after I changed those.
Check the Alignment, knuckle bushings, and toe arms
6th Gear
6th Gear
It was way back but I remember having to replace one of the camber bolts because the alignment wouldn’t stay. Also had to change the knuckle bushings. Gotta lift the rear up and grab the wheel at different positions and see if you can feel any play then trace that back to the problem.
Then I started having alignment issues and just a sloppy loose feeling rear end, especially over bumps. I realized how important those bushings are for alignment since they are directly connected to the camber adjustment. They had so much play when I took them out. Any bump would knock the alignment out. Changing them made the world of a difference for tightening up the rear end and high speed stability.
I was told by the shop that did an alignment after it was lowered that something was maxed out but “it will ride fine” and it did for almost a month before I stared having this issue, I have noticed the tires seem to be wearing quickly, but assumed it was because of the camber, not much but a bit, the alignment sheet showed it was slightly out of the green on the driver side but you bring up a good point.
