Color Code
Color Code
Where is the color code locate on the gs400 try looking on both doors,under hood nothing indicating color code, anyone with picuture also thank you need asap painting my kit tomorrow...
the color code is on the car when u open the door..its a white stiker and it should say c/tr than the code...its usually the 1st 3 set of numbers or code like mine in 8m6 the other set of codes after trhat is 4 the interiot color code...
Forum Administrator
What Blue said. To be illustrative...
GX and 2IS Moderator
Doesn't make sense
KNKGS400,
the color code should be 3 characters... in Dave's example C/TR is Color/Trim the 202 is for Black, and the LB00 is for Leather - Black.
Originally posted by sung35
Just curious. Beside color code, what else does the sticker on the door can tell you. I can figure out the tire pressure. Anyone knows?
The second line give the weight of the vehicle. That's of couse without my fat *** in it!
Rest of stuff is how weight of vehicle is distributed on front vs rear at specific tire pressure.
