Squeaking noise from front left wheel+ crunshing noise when car is warmed up
2nd gear
Hi everyone,
im facing a strange problem with my 01 GS430. First i noticed a strange squeaking noise from the front left Wheel when driving slow (approx. Until 10mph after that its gone) had that noise a few weeks after i bought the car. Already did the front brakes completly + ball joints (previous owner didnt replaced them).
After i replaced the brakes, a crunching noise additional occured but only if i drive the car for a few km‘s.
The brake disc isnt touching anything (what i first thought), thats the point that is driving me nuts as i now its coming from the left wheel bit not the disc as i thought. I dont now if its the wheel bearing maybe?
hope you guys can help me, i have attached two videos where you can hear both noises.
1. Lift the wheel off the ground and spin / shake it well.
2. Remove the wheel, put a couple wheel nuts back on the wheel hub to hold the brake rotor in place and spin it again.
3. Listen and identify the source of the noise.
QLex300 (08-06-23)
The test was performed incorrectly. Install a pair of wheel nuts back onto the wheel hub and tighten them slightly to hold the brake disc in place. Then shake and spin it.
