SRS light on
SRS light on
Mine is 05 GS300 ~150K miles got SRS light on. check manual on more than 6 sec is front bags and flash is side bags. OBD327 scanner shows no error code. Thanks for any advice.
Another thing is when I change gear from fwd to bwd or bwd to fwd I hear cranking sound two times, sit outside sounds come from both front and rear wheels, only drive side sounds slight less. I mean 3.5 wheels have such sounds but drives fine, sounds lasted a few months already. I used to replace lower control arms and remove struts, but all torque are met and sounds would happen before my replacements, not now it is heavier.
thanks for advice.
thanks for advice.
cpenney
03-26-12 09:09 PM
