Glove box rattle FIX!!
Old 11-12-03, 09:38 PM
Blanco
Blanco's Avatar
Default Glove box rattle FIX!!
For those who pm'ed me about the infamous rattle, I submit the long awaited pictoral diy resolution! Based on my limited knowledge I'll be posting one pic per post, each one being a step. The whole process is easier than it looks. I had two types of felt both came in large sheets from 3M. My local Lexus repair shop just gave them to me. One sheet is thick (1/16'-1/8"), the other much thinner, almost like fuzzy tape, both black.
Other than the felt stated above, the tools needed are: Philips screw driver(cordless makes it go MUCH faster), 10mm nut driver/ratchet, and maybe some needlenose pliers.
For anyone else that's done this please feel free to contribute your opinion!!
Start by disassembling the glove box. Remove black kick panel. I just pryed it loose with my fingers.
Old 11-12-03, 09:43 PM
Blanco
Blanco's Avatar
Default Step #2
Remove panel light by twisting. Panel should slide out. Next remove bolts at either end on bottom.
Old 11-12-03, 09:46 PM
Blanco
Blanco's Avatar
Default Step #3
Next, remove screws along top. At this point box should almost be ready to yank. Mind the wires on the right!!
Old 11-12-03, 09:50 PM
Blanco
Blanco's Avatar
Default Step #4
Carefully remove wires. The light simply unplugs The changer harness is a little pinching. Then push down. Once loose twist and pull back through hole in box
Old 11-12-03, 09:57 PM
Blanco
Blanco's Avatar
Default Step #5
Now you should be able to remove glove box and box door as one assembly. I took mine to kitchen table for further work. Now we want to separate the "box" from the "door". First detach hinge arm from door. This will take a bit of effort once the 10mm bolt/screw is out. Mine popped off from both ends.
Old 11-12-03, 10:02 PM
Blanco
Blanco's Avatar
Default Step #7
Now remove hinge pins, then slide drawer stops from box tracks. Pinch in and push back out.
Old 11-12-03, 10:06 PM
Blanco
Blanco's Avatar
Default Step #9
While I was at it I felted the door at the back of the back that allows access to the a/c filter. Tape felt was used on end nipples and bottom when it sat in back of box.
Old 11-12-03, 10:07 PM
Blanco
Blanco's Avatar
Default Step #10
Now remove screws around perimeter of door.
Old 11-12-03, 10:10 PM
Blanco
Blanco's Avatar
If you squeeze the two and hear plastic creaking then you need the felt. Where there is creak there should be felt.
Old 11-12-03, 10:11 PM
Blanco
Blanco's Avatar
again
Old 11-12-03, 10:13 PM
Blanco
Blanco's Avatar
Default Step #11
Now here is where I used the thick felt. I had to place strips around the sides and the front mostly.
Old 11-12-03, 10:15 PM
Blanco
Blanco's Avatar
Felt should be coincedent tothe edge, but not over.
Old 11-12-03, 10:20 PM
Blanco
Blanco's Avatar
Don't want sloppy work showing where peeps can see. So attention to detail is needed when placing felt, or you could use a knife to trim. I don't like the idea of accidentally cutting into door or plastic so I had to reset this piece after the fact.
Old 11-12-03, 10:22 PM
Blanco
Blanco's Avatar
Felt on a/c filter door.
Old 11-12-03, 10:23 PM
Blanco
Blanco's Avatar
I also placed the thin fuzzy stuff here to help.
Quick Reply: Glove box rattle FIX!!
