Hesitation
Originally posted by PHML
I don't do this but I know a few ppl who swear by it.....MOTH ***** (must contain Naphthalene) to boost octane in your gas tank.
Pete
Moth *****
Moth ***** can be used to increase the octane rating of the gasoline your are using. The higher octane not only increases power, but will also increase gas mileage. The ratio is 5 moth ***** for every 1 gallon of gasoline. Place moth ***** in gas tank before fueling the car. Also add 1ounce of WD40 per gallon of gasoline. This will help remove water from the gasoline and make it ignite better.
( Note: The moth ***** must contain naphthalene.)
Pete
Moth *****
By the way, bmgs400, since you're using octane 89, your car's computer probably retards the timing a few degrees to prevent engine knocking (and reduces performance). Thus, you'll have a delayed response in your engine. Use quality supreme gas, and see if that helps.
Thanks SeattleGS, we shouldn't be cheap when feeding our GS's. I filled with 94 octane last night and I was using 87 octane...cheap stuff not good. I agree when you said the timing is being retarded some to prevent engine knocking. I remember reading that somewhere before. So anyway, I also pulled the ECU-B1 fuse and replaced after 20 minutes or so. This seems to make a difference, I can't really tell today with all the rain. I'll mash it when the roads dry.
Hey croz, how's the GS now?
I had a problem where my GS4 would lag most of the time, mainly when the car had first been started wether I was at a stop or pushed the pedal down while going 60... my problem to out to be a fuel regulator sensor..
JonSC4
Performance & Maintenance
12-14-09 12:27 PM
