Ac
Ac
Ac issues
i have a code for 43 and 42 but my ac isn’t getting cold but the compressor turns on and it has refrigerant I’m waiting for the actuator to arrive but will that cause it to not work
“Actuator”? What actuator? Is it blowing hot air or just ambient air? So the compressor is coming on and then cycling correctly? Have you checked the interior ambient air temp sensor? The servos are working and it’s switching from the heater core over to the a/c evaporator when you change the settings? Can you hear the servo changing modes when you turn the temp from 65 up to 80? You should be able to hear the servos changing modes when you cycle thru the different settings and modes. There is a servo that could be stuck in the hot air mode.
