Tires slide/spin around corners
I looked for the answer but could not find one. If I take a 90 degree turn ( normal corner) and accelerate from say 5mph to anything above this my rear tires slide and the traction control lights up. I am not "gunning" it or anything though. I can not figure out why this is happening. Could it be a suspension problem that is allowing one of the wheels to loose traction? the tires have about 50% of the tread left.
Thanks
Thanks
I'd be weary of taking VSC off. I dont want to hear about another GS in a wreck. VSC helps stop the tire spin. If I take my VSC off and push it at a light, my tires are spinning pretty good. With VSC on there is just a chirp of tire spin.
I'm on a GS3 -- The GS4 with 300+ ft/lb of torque is known to light up the tires kind of easy. I'd check in a better tire with a stickier tread pattern.
Check the classified section, there're several LSD for sale. Those're the answers to you tire spinning problem I learned that lesson long time ago. I had my TRD LSD installed 6 months after I owned the GS4.
Re: Tires slide/spin around corners
Thanks
Thanks
now i really think my tranny might have probelm or something...when i step on it really hard at the light, my car feel very weak until 4k rpm(just like turbo lag, but its a bad lagging).....i have never peel out a lil bit from stop, should i take it to the dealer or is there anyway i can fix that?
i have S03s on, rims are not heavy at all....18lbs frt and 20lbs rear
Well, there are two explainations for what you are experiencing...first of all, the lag you speak of is a pretty common problem in our cars. If you don't know already, the ECU adjusts to the driving pattern of the driver, so resetting the ECU may help you out quite a bit. Also, this is my second set of SO3's and I have found them to be almost completely silent when peeling out. Even when the tires are spinning you can hardly hear anything, so maybe you really are spinning them and you just can't tell. Have someone stand to the side of you when you launch...chances are they will be able to hear it.
the SO-3 grip level is much higher than any all season or snow tire, so without brakestand launches the tires most likely wont spin. I seriously think you guys should find a big empty parkinglot at night, turn the VSC off and practice what happens when the tires loose grip... VSC will not save you in the event of an emergency, it may help, but the car will still get very loose, i have video from the drift day of me tossing the GS, forgetting the VSC was on, and i was already totally sideways before the VSC kicked in, remember that the VSC only activates once it sences a loss of grip at one of the tires. If the car has enough inertia before it breaks loose (feint motion) the car will slide, regardless of VSC.
I also find VSC to actually push the tail out more, before bringing it in, because when you initially have inside tire spin, it brakes the inside wheel, acting as an LSD, transferring the power (just before it cuts) to the outside tire... this is just want i noticed
davidwd40
04-05-12 08:49 AM
