GS really BAD on Snow
#46
Yes I tried everything. I found out after the fact that I needed tires. They weren't bald but close!
Even when I was on a flat road and only was rolling at a light and tried to slow down, it skidded all over.
I have not been in the snow since I got new tires so I'm going to see how they work.
My mechanic told me to put sand bags or something similar in the trunk so I'll try that as well. Either way, I would never trade my car in. It's too much fun!!
Thanks for the tip!!!
#48
My blue GS4 has stock GY 16's, and it is horrendous in the snow. I also am not confident that the Snow Mode does much more. Is consensus that we should merely use Snow Tires? And yes, GS4 experiences much more of a problem than GS3. Pops LS430 is heavy and powerful, but no real issue. Why?
#49
Not to add to the mystery, but...
I swapped snow tires front to back this year. The last two days the car was skidding and slipping everywhere - and we basically didn't have any snow! The roads were just slightly glazed. Last night I actually almost spun the car turning left and it was not a hard turn.
These are 1 year old Blizzak LM-22s.
This leads me to believe that either
a) car has an alignment problem that suddenly appeared (don't think so)
or
b) the tires are very sensitive to their position on the car.
or
c) My GS is possessed![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
All I know is that I have some of the most expensive snow tires and they are suddenly worthless. I'm swapping them back this weekend.
or
or
#50
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
Originally posted by koreanpers
i think it is so funny that our cars beep at us when we lose control....is there anyway to turn that beeping off? i mean, its already bad when we lose control of our cars....but then to compound the issue we have to hear this annoying beeping sound in our ears...lol
#52
I've got a GS in IL too and I have zero problems with my snows. I do have Artic Alpins on all 4 wheels so that might be the difference if I read your post correctly, you only have two. Everything I have read says you should always mount them at all locations and not mix with all season or performance tires. That might be your issue. A glazed road causes problems whether you have snows or not, anytime you have ice the AWD, 4WD, snow tires, etc. have much less to no effect on ice.
#53
doug has snow tires at all four wheels. i've got blizzack ws-50's which really stick to ice like it's dry pavement, they are mind blowing in their traction on ice, but with the global warming we don't seem to be getting the ice and snow that we used to get. i'm up in seattle washington. i can't stand to drive on them on just wet or dry roads, i took them off a couple of weeks ago and will wait untill snow is coming before i put them back on.
#54
Ivan (3Dog) is correct. I have them on all four wheels. I have a sneaking suspicion that they just don't like to be rotated however. His Blizzaks (the WS-50s) are the best snow/ice tire - period. But as he points out, there are terrible in the dry. My Blizzaks (LM-22s) are much better in the dry but not as good in the snow and especially ice. However, since rotating them, the rears feel out of balance at speeds above 60 (had them balanced by Lexus). I'm having them moved back to their original locations this week.
Aggie, were you having problems this last week with traction? Just curious.
Thanks,
Doug
Thanks,
Doug
#55
Originally posted by 3dog
are you hearing "this annoying beeping sound" everyday , once a week , or less often than that. if its less than that just ignore it. if its everyday i' m glad the whole country separates our two cars.
#57
Thanks,
Doug
Thanks,
Doug
I'd consider the LM-22's a compromising cross between a hardcore snow tire and an all-season tire. Not quite the best for snow, but not the worst for dry roads either. . .
Anyways, I'll get the Bridgestone WS-50's or maybe Michelin Arctic Alpines for another winter as I'm not risking a wreck in my GS due to inadequate snow traction tires (as I have no need to drive fast in the winter). . .
#58
I have never heard a bad thing about the Dunlop WinterSports. I regret not getting them - TireRack recommended the LM-22s however. Unfortunately I have received bad adviced from them more than once.
#59
I just switched from my Mich A/S on 17" Chrome to Blizzak on 16" alloy as I do every winter. The Blizzak are incredible I never have a problem and the car drives great in snow.
Blizzak
Blizzak
